Sweating warehouse floor in feed mill
Any sealer suggestions for stopping warehouse floor in feed mill from sweating in humid weather.
Sweating warehouse floor in feed millSweating warehouse floor in feed mill(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: Sweating warehouse floor in feed mill
cool floor and warm humid air will condinsate on floor
is the water table real close to the surface?
did the contractor put down a plasic vapor bariar before they poured the concrete?
for us plains state guy, this time of year is cold and dry mostly, if you can get the floors dry, you might try the white concrete block sealer on areas with mild trafic, this will keep the mosture below the surface.
Location has a lot ot due with how you can fix this problem
Bill Loutzenheiser VP-CTO
Phoenix Castings
Central Nebr., USA
You ned to super clean the floor first, with a mild acid ( yuk)
then after you roll down the paint, sprinkel it lightty with dry sand,, it makes sweeping dificult but you get added traction from the sand
also you may find that the paint may help a lot??
we get some of that same thing up here in Nebraska
bill
Phoenix Castings
Central Nebr., USA
Do you notice moisture on metal items in the area when the floors show up wet? I'm thinking grinders, motors, metal castings, etc..
If you do, it is due to condensation and not ground moisture.
I have this problem in a shop that has a well insulated floor with a good vapor barrier.
Griffy
any moisture or was it dry
Bill
Phoenix Castings
Central Nebr., USA
I'm not an engineer...........but I think the sweating is a result of a hydroscopic effect from perhaps the salt contents of the feeds and dust and not a sub floor moisture problem.
My first day here; nice site and forum!
Be safe.
Royal A. Purdy
The Elysian Fields Pasture Project
