Were's the Pitch
Were's the Pitch
Were's the Pitch
I'm detailing a part in 2005 SP0.1
I'm using metric hardware and all holes were created using the hole wizard selecting size and pitch.
When I go to detail I use the hole callout and it shows up as a threaded hole with most of the information but the pitch is missing.  Instead of getting M8x1.25 I just get M8.
I looked in the calloutformat.txt but didn't find anything about a pitch callout.  The callout for the tapped hole is given as <hw-threaddesc>, which is the same as the imperial threads which detail fine.
Any suggestions for making this work?
RE: Were's the Pitch
Do a search on this topic.
It was descussed here a few weeks ago. That's how I fixed this problem.
Check this thread out Thread559-106075
