Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...A lot of the information I've found at this site would've taken me forever if I'd have attempted to research it on my own. Thanks again."
Geography
engoz (Mechanical)
13 Sep 01 20:03
Hi there,
         I have two questions here but the first and most important is I'm trying to find out the flow of steam from the top of a return condensate tank from a sugar mill pan area so I can work out the condenstae loss.  The pressure in the water tank is 75kpa and their is an open 6 inch gate valve on top of the tank which lets out the steam from the water.
        The second is I want to put some sort of steam trap on this 6 inch outlet pipe to save this condensate loss.  Is this a possibility for this application?
Thanks in advance,
MortenA (Petroleum)
9 Oct 01 5:11
You need to find the Cv (or an quvalent measure for pressure loss in the valve). Then you can calculate the steam flow through the valve (usually the valve manufactors handbook will have the equations).
In theory the steam should remain as steam unless you cool it. So you will ned a condenser to "catch" the steam. Then a pump to feed it back into the vessel.
A steam trap is usually intended to remove condensate that occurs from (unwanted) cooling of a steam carrying pipe.
Best Regards
Morten
Close Box
Join Eng-Tips® Today!
Join Us             Close
