Object Selection
Object Selection
I have changed something in AutoCAD 2002. I am no longer able to select multiple entities except by Windowing. I used to be able to select multiples by holding down the CTLR key and selecting with Left Click on mouse. Does anyone know which property I changed accidently??
Thank You
Thank You
RE: Object Selection
This might help you a bit tho...I discovered under TOOLS\OPTIONS\Selection Tab a setting for "Use SHIFT to add selection". I normally have this option UNCHECKED. I discovered that when I CHECK this option, then I lose the ability to select multiple entities with multiple left mouse clicks.
It could be that 2000 and 2002 are different enough that the info I gave you here is totally useless too.
I hope that this information from CarlB and/or myself helps you out in AutoCad 2002, 11991.
