Use of spring elements
hi,
I have a Two solid rectangular blocks meshed using solid 3-D Brick elements. Spring elements have to be used to connect the two blocks. So i have used node to node spring elements at the interface of the two rectangular blocks. My doubt is to whether divide the total stiffness by no of springs OR give the total stiffness to each spring element.
Thanks in advance
Thanks in advance
RE: Use of spring elements
Cheers
Greg Locock
David R. Dearth, P.E.
Applied Analysis & Technology
