Sap 2000: shear wall
May I use frame elementes with end offset for modeling shear walls?
RE: Sap 2000: shear wall
My opinion is that yes, you can.
If the shearwalls form a core then you may need to model directly rigid links as an alternative (out of the more complicate relationship to the center of gravity of the core line element.
