Catalog Data for Power Piping Spring 716
Hi Forum members,
Please help me find catalog data for a Power Piping spring size 716. That is spring rate and range of movement.
Thanks in advance,
Alligator
RE: Catalog Data for Power Piping Spring 716
If this is an existing, in service, component, is it possible to have someone look at the placard information on the spring can for the info?
My old "Catalog 90" shows the 716 to have a KY=800 lbs/in and a recommended load range from 5600 lbs to 10800 lbs with 8000 lbs at center scale. This spring has a total deflection range of 8 1/2" but the catlog recommended range is 6 1/2". This spring will handle deflections from 2" to 3" and be within 25% load variablity.
Good Luck,
NozzleTwister
Houston, Texas
