API STD 607 FIRE RATING
I require information reguarding the API std 607 fire rating pertaining to wellsite separator / metering facilities.
The application involes a actuated ball valve located
inside the separator building.
The actuated ball valve is operating as a ESDV to
fail close.
I would like to know if this valve, because it is operating
as an ESD, must conform to the 607 fire rating or is it
a voluntary guideline that specific companies tend to go by.
fail close.
RE: API STD 607 FIRE RATING
I NEED KNOW IF API 600 GATE VALVE CAN BE API 607 FIRE SAFE TOO.
THANKS A LOT
