Automatic Transmission clutch losses?
Has anyone ever measured parasitic losses from the clutch packs of various Manufactures of Automatic Transmissions?
What I mean is say, with the transmission in top gear, the unapplied clutches will be coasting and washed in Transmission fluid, so there is a certain amount of drag or loss from this. Also I realize it will be different from transmission design and clucth pack size and design. I'm just looking for some close approximations.
Thank you.
RE: Automatic Transmission clutch losses?
icrman,
From SAE Paper 1999-01-1259, clutch pack drag parasitic losses in a typical AT represent about 75% of losses in the transmission. The total losses in an AT can be from 10% to 20% depending on the operating conditions.
Worst case, 75% of 20% would be 15%. Close enough for you?
Terry
How about band type clutches. Is there any info on them?
