Contact constraint on 2-D elements
I have a problem with FEM statc analysis. I've used a 2-D FEM mesh for sheet metal, but I can't use contact constraint now, because it can be only used between two solids (CATIA V5 R10). What kind of contacts are the best alternative (or is there any way around it?). Thank you.
RE: Contact constraint on 2-D elements
Precisions and Restrictions
Here you will find precisions and restrictions for certain connection properties.
Contact: Contact Connection Property, User-Defined Distant Connection Property (if you select Contact as Start or End option).
Can be generated only on a geometry belonging to a 3D body.
