IEEE standards for PLC and SCADA system
what is IEC standards or codes used for PLC and SCADA system (Hardware and sotware standards)?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: IEEE standards for PLC and SCADA system
IEC standard for PLC - IEC 61131
Also have a look at following site
http://www.plcopen.org/
Ideas that Works and
Concepts that Sell
IEEE covers most of the communication protocols.
IEC 61131 is available in at least eight parts. IEC established a programming standard for ladder and other logic. Most manufacturers are compliant. The design of safety systems should comply the lates ISA 84.00.01 or IEC 61511 or 61508 and include TUV rated components. The rapid changeing technology is one problem with PLC related codes and standards. ANSI/ISA–S91.01–1995 is titled "Identification of Emergency Shutdown Systems and
Controls That Are Critical to Maintaining Safety in Process Industries". Also check IEC 61131 and 60167 to see if they may apply.
John
Odd ‘n’ ends… {Some probably hopelessly archaic}
C37.1-1994 IEEE Standard Definition, Specification and Analysis of Systems Used for Supervisory Control, Data Acquisition, and Automatic Control
999-1992 PDF IEEE Recommended Practice for Master/Remote Supervisory Control and Data Acquisition (SCADA) Communications
1613-2003 IEEE Standard Environmental and Testing Requirements for Communications Networking Devices in Electric Power Substations
1267-1999 IEEE Trial Use Guide for Development of Specification for Turnkey Substation Projects
1379-2000 IEEE Recommended Practice for Data Communications Between Remote Terminal Units and Intelligent Electronic Devices in a Substation
Possibly applicable titles:
ht
http://standards.ieee.org/catalog/olis/im.html
htt
IEC 60488.1-2004 IEC/IEEE Higher performance protocol for the standard digital interface for programmable instrumentation – Part 1: General
IEC 60488.2-2004 IEC/ IEEE Standard Digital Interface for Programmable Instrumentation--Part 2: Codes, Formats, Protocols, and Common Commands 61588-2004
61588-2004 IEC/IEEE Precision clock synchronization protocol for networked measurement and control systems
There’s also C37.111- and 1159-type standards that somewhat mesh with SCADA in utility settings.
