Domestic Water Lateral for Irrigation
I have not worked on many civil engineering projects that involved domestic water lines, so I have a very basic question. I am designing a parking lot that requires irrigation lines for landscaping. My landscape architect is designing the irrigation lines, so all I need to provide him is something for him to tie his line into. There is an existing 16" domestic water line in the adjacent street that I plan on connecting a service lateral to. What information do I need my landscape architect to provide me, and what else do I need on my service lateral (meter, backflow assembly, pressure reducing assembly, etc?
Jeff
Jeff
RE: Domestic Water Lateral for Irrigation
sfritten was right that you need to check with the local water district or if it is under the city's jurisdiction, city water department. The landscape architect just needs to give you the size of meter and service connection he needs. If it is a parking lot you will probably need between a 1" to 2" service connection, backflow device & meter. Most water departments have typical details or standard plans that you can get a copy of and refer to on your plan. Then submit your plan to the water department for approval. Just so you know the meter will probably need to be in the public right-of-way so that it can be read by a water department employee. The backflow device will need to be located within 10' feet behind the property line. Good luck and let me know if you have any further questions on this topic. I've done this countless times in the past.
Canman
