Config. Name in BOM
Config. Name in BOM
I'm using two configurations on an assembly (Fabrication and Machining). On my drawing, I have a BOM and in the 'QTY' column, the configuration name is displayed with the title (Fabrication/QTY). I can edit the title and remove the word Fabrication but whenever I rebuild or re-open the drawing 'Fabrication' always comes back. Is there some type of option to 'Not show config. name in column title'?
Sean Nutley
Carmanah Design and Manufacturing
Vancouver, BC, Canada
www.carmanahdesign.com
RE: Config. Name in BOM
Scott Baugh, CSWP
3
CorBlimeyLimey (Mechanical)
Actually there is a workaround for this.
LesPaul82 (Mechanical)
It worked!! Thanks a lot. This was extremely helpful!!!!!
SBaugh (Mechanical)
Dang, I always forget about that. Thanks CBL!
3DVision Technologies
http://www.scottjbaugh.com
Merry Christmas
Remove the . after QTY when editing the Column name.
So Config/QTY. becomes just QTY
Sean Nutley
Scott Baugh, CSWP
Merry Christmas
