mirroring a pattern
mirroring a pattern
mirroring a pattern
How do you mirror a pattern in Wildfire.  I'v created a hole pattern array andthat I'm trying to mirror and when I select the pattern the mirror button will not highlight.  Anybody know what I'm doing wrong?
Thanks.
RE: mirroring a pattern
To do this, you need to use the "old" mirror function.
Use Edit-->Feature Operations-->Copy-->Mirror/Dependent
Then, select the pattern, and finally the mirror plane.
Happy Holidays
Mark
