Cutting Rubber
Cutting Rubber
Could someone help me out I'm trying to cut 90 durometer rubber. The geometry is OD of 1.5x .5 long step down to OD 1.375 x .5 long with 2 (.5 dia) x .5 deep flat bottom holes on it. tolerance is +/- .015. All dims in inches. I tried sharp turn tool, sharp endmills, fast, slow. Is grinding feasable? Any help would be appreciated.
RE: Cutting Rubber
<nbucska@pcperipherals DOT com> subj: eng-tips
read FAQ240-1032
RE: Cutting Rubber
RE: Cutting Rubber
RE: Cutting Rubber
RE: Cutting Rubber
Is this a one off or a production job?
If one off, use a high rake angle tools(check definitions in Machinery's Handbook). High rake should peel this like an apple but the higher the rake, the less the edge life.
If high production, you may want to look at having the part cast to net size.
Griffy
RE: Cutting Rubber
Thank you for correcting my rake angle zero reference!
