Angled Hole on Non-planar Surface
Howdy. I am trying to place a tapped hole on a non-planar surface.....but I need the hole to be placed at an angle to this surface, not perpendicular to it. I can get a hole normal to this surface by just inserting a hole.....but I can't angle it or make it follow a path (axis or construction line). Any ideas. Thanks
RE: Angled Hole on Non-planar Surface
You can use Cut > Extrude or perform a Cut > Revolve to place your flat surface on your skewed surface.
There are also other ways of doing this that others will probably post.
Jeff Mowry
http://www.industrialdesignhaus.com
Reality is no respecter of good intentions.
Use a 3D sketch to define the hole axis. Then you can create planes, axes, sketches, etc. referencing the 3D sketch.
Jeff Mowry
