Cutting PVC pipes.
Cutting PVC pipes.
Hello:
Anybody out there knows a better way to cut off PVC pipes than with a mechanical saw . Currently we saw them and then scoop out the plastic burr....pretty time consuming; IS there a PVC pipe/tube cutting machine that cuts clean.
I am talking about 6"OD pipes.
Thanks for the help.
-mechantaeus
Work Hard and Work Smart.
RE: Cutting PVC pipes.
They make from 3" to 12" both supply and waste water pipe.
