File naming conventions
We are a yacht builder that uses Solid Edge. We build nine different powerboat models and seven different sailboat models, and we have an MRP system. We are trying to devise a way to tie the drawings to the MRP but still keep the drawings esy to identify when we search using Windows Explorer. Does anyone have any good file naming system/practice to do this. We are thinking of using a combination of a numeric (for the MRP part) and naming system but are not sure if there any hidden traps here. Anyone have any advice?
Peter
Peter
RE: File naming conventions
The downside to this is that it requires a bit of discipline in filling in the properties in a consistent manner, but this can be done easily with the help of a simple VB bolt on. Also, use a really simple folder structure - it will pay dividends later on.
You could try Insight - which works on a similar principle, it is supposed to help the workflow and facilitate easy quick & searching on properties but I have very limited experience of using it so I can't say if it really helps or not.
