Model check windows have bar to allow blocked content
When I run model check and ask for a report, instead of the usual report I used to get on my old Windows 2000 system, I get a window that has a bar on it saying Click here to allow blocked content. Then there is a pull down on it to select view, then another window to accept.
I am running XP with the new service pack and Proe 2001.
I made the changes suggested by hitting the help function but it still wont stop blocking and making more work to get the report.
Can someone tell me what needs to be set here to eliminate this?
Thanks in advance!!!
RE: Model check windows have bar to allow blocked content
Im not able to help you but I wonder when you say "Model check" you mean like in "Model checking/model verification" related to the hybrid automata and HyTech, Kronos, UPPAL, etc.
thanks
Juan Fuentes
I have not run into this problem yet (been off MC for a while)... But you might want to try to have Pro/E use a different browser. Try downloading Firefox and changing Pro/E's browser path to that instead of Explorer. Firefox has script blocking as well, but at least you can control it. As soon as SP2 came out, that was the last time I ever used Internet Explorer, and I'm not looking back.
