table.pnt FILE
table.pnt FILE
Dear Pro users,
I am using Pro/E 2000i and Intralink 1.2
I have a Pen table file (table.pnt) which is controlling my plotting requirements. I want to take this file into commonspace of Intralink but it says an "invalid file extention". I then went to Pro Admin and defined an extension "*.pnt" but still the same error is being shown.
Kindly Suggest.
Kindly Suggest.
Amish Bhushan Goel
Engineer
Hitech e Soft
amg@hitechesoft.com
RE: table.pnt FILE
I kept my PNT files on the server.
If you remove the PNT path in the DTL, the PNT that is in worksapce is used ( at least thats what I think ).
What would happen if it was not in a workspace?
As a rule, I am trying to get all Pro/E objects into commonspace as well. Any suggestions/experiences to note?
RE: table.pnt FILE
I think it is not possible to move the *.pnt file into commonspace even after creating a system environment variable in NT.
Instead I have made a batch file which copies the config, dtl and pnt file in the text directory of proe and then proe is invoked from that folder. This maintains a uniformity along the organization regarding the plot configurations.
Amish Bhushan Goel
RE: table.pnt FILE
