Electronics protection from condensation
How do manufacturers of aircraft electronic instruments protect the electronic components from condensation when aircraft descents rapidly from high altitude to ground?
RE: Electronics protection from condensation
Wheels within wheels / In a spiral array
A pattern so grand / And complex
Time after time / We lose sight of the way
Our causes can't see / Their effects.
This additional internal heating may sometimes only be required while the equipment itself is powered down in some instances. The main on/off switch can energize the heating resistor in the off position.
I know nothing of aircraft systems, but have seen heaters used in underground mine electronic equipment, and marine applications where cold and damp are problematic.
The other solution is a hermetic enclosure and a silica gel pouch, some military equipment is like that.
Mike Halloran
NOT speaking for
DeAngelo Marine Exhaust Inc.
Ft. Lauderdale, FL, USA
I guess same applies for the electronic component use in aircraft also.
Ideas that Works and
Concepts that Sell
