USB device driver for optical sensor?
I am new to this forum and hope this is the right place for my question.
I have an optical PH sensor using a USB port connect with my PC, so I can read data from the sensor. Now the problem is I have to connect the sensor with a single board computer, on this board there is only MS-DOS system and no USB drivers. Do you guys think it is possiable to write a driver for the USB port under DOS for this particular usb port from the sensor? Could you give any suggestions or advices about how to write a usb driver? And any places I can study on the website? Very appreciate for your help.
Thanks in advance,
Lidan
Thanks in advance,
Lidan
RE: USB device driver for optical sensor?
Wheels within wheels / In a spiral array
A pattern so grand / And complex
Time after time / We lose sight of the way
Our causes can't see / Their effects.
I did some limited leg work, appears that it is not likely to find a serial (PC side) to USB (device side) converter. The other way is feasible. Is there a PS/2 port on the SBC?
Is this SBC plugged into an expansion bus, or is it completely standalone?
