ASME Stamps & new owner
If a company that is not an ASME stamp holder buys an ASME code shop, can the existing stamps be used in the continued operation of that shop under the new owners? What is the cost to transfer these or get new stamps?
Typically ASME Section VIII unfired pressure vessels and small fired vessels, oil-field type equipment.
RE: ASME Stamps & new owner
you can use the same.
For pricing of new stamps contact the ASME Acredittation
you are to spend a few thousand Dlls (10,000k to be an pprox)
ER
