below is the sub to open AutoCAD pr
below is the sub to open AutoCAD program... but how do i change it to.. when i had open a AutoCAD file... then.. it will on automatically open another blank AutoCAD new file??
Public Sub OpenAutoCAD()
Dim DwgName As String
On Error Resume Next
Set acadApp = GetObject(, "AutoCAD.Application")
If Err Then
Set acadApp = CreateObject("AutoCAD.Application")
Err.Clear
End If
If Right(App.Path, 1) = "\" Then
DwgName = App.Path & "facility.dwg"
Else
DwgName = App.Path & "\facility.dwg"
End If
Set acadDoc = acadApp.activedocument
If acadDoc.fullname <> DwgName Then
acadDoc.Open DwgName
End If
acadApp.Visible = True
End Sub
If Err Then
Err.Clear
End If
Else
End If
End If
End Sub
RE: below is the sub to open AutoCAD pr
Note:
You should put the Err.Clear command before the CreateObject statement, handling the error before proceeding with the program.
If Err Then
Err.Clear
End If
DimensionalSolutions@Core.com
While I welcome e-mail messages, please post all thread activity in these forums for the benefit of all members.
i'm trying to change the code to.. when it detect the AutoCAD program is opened.. then it will open another AutoCAD blank file...
for example...
case1.) an AutoCAD file has already opened... so when i run the sub... it will open another AutoCAD file(so that, there will have 2 autocad drawings in the autocad program... one is the existing program.. and second is opened by the code)...
case2.) when don't have any autocad opened... then it will open an autocad file..so it will only have 1 autocad drawing in the autocad program
i wish i make it clear this time...:)
If Err Then 'AutoCAD is Not Opened
Err.Clear
Else 'AutoCAD is Already Opened
'Open a new drawing here
End If
Else
End If
End If
End Sub
coz i have tried the code that you corrected... but i still the same.. i can open a new AutoCAD file...:((
Sub Ch3_NewDrawing()
Dim docObj As AcadDocument
Set docObj = ThisDrawing.Application.Documents.Add
End Sub
acadApp.Documents.Add
i should come here earlier ask my questions....i really spend a lot of time to look for the answers....
anyway.. thank a lot!!!
Dim a, b, R As Variant
a = utilObj.GetPoint(, vbCrLf & "Start of shear wall: ")
b = utilObj.GetPoint(a, vbCrLf & "End of shearwall: ")
'but I am not able to determine the angle R:
R = utilObj.AngleFromXAxis(a, b)
'because of a 'Type Mismatch' error. The AngleFrom
'function expects 3-element array of doubles.
'How can I convert the 'a' variant to 3-element doubles.
Dim a(0 To 2) As Double
Dim b(0 To 2) As Double
Dim R As Double
DIM a(0 to 2)
then an error comes up on the 'GETPOINT' line when you try to run it
DIM a(0 to 2)
Dim utilObj As Object
Dim a, b
Dim pt1(0 To 2) As Double
Dim pt2(0 To 2) As Double
Dim dAng As Double
Set utilObj = ThisDrawing.Utility
pt1(0) = a(0): pt1(1) = a(1): pt1(2) = a(2)
pt2(0) = b(0): pt2(1) = b(1): pt2(2) = b(2)
dAng = ThisDrawing.Utility.AngleFromXAxis(pt1, pt2)
Dim a, b
Dim dAng As Double
dAng = ThisDrawing.Utility.AngleFromXAxis(a, b)
