Bearing support stiffness
I'm looking for info on the range of bearing support stiffnesses that might apply to 2000 HP, 6-stage, barrel-type centrifugal compressor running at 10,000 rpm. Not bearing stiffness, but the Kxx & Kyy stiffnesses of the bearing housings themselves.
I'm performing a rotordynamic analysis of this compressor. I don't have time or access right now to perform an impact test, so would like to approximate these stiffnesses with data from similar installations.
Many thanks!
Tom
Many thanks!
Tom
RE: Bearing support stiffness
Cheers
Greg Locock
