Enovia and JRE
Enovia and JRE
Does anyone know if Enovia LCA V5R13 can run with Java Runtime Environment 1.4.2_04? I've not been able to track down the requirements for Enovia and all testing seems to point to happiness only with JRE 1.3.1_09.
Thanks....
Thanks....
AJT
Manufacturing Engineer
The Boeing Company
St. Louis, MO
RE: Enovia and JRE
From what I have experience so far with Dassault’s products, it's always better to go with the requirements. Even, if higher releases are available.
For LCA V5 R13 Client and Server Sides
- Java Runtime Environment, version 1.3
- IBM AIX: IBM Java Runtime Environment version 1.3.1.13
- HP-UX: Java Runtime Environment 1.3.1.5
- SGI IRIX: Java Execution Environment 1.3.1.2
- Sun Solaris : Java Runtime Environment 1.3.1.12
- Windows : Java Runtime Environment 1.3.1.8
Information can be found at :
http:
Cheers
Sean
