Oxygen friction loss calculation?
Does anyone have the formula to calculate Oxygen - I want to know the friction loss if given the LPM and the pipe size.
I was trying to work with a chart in a spreadsheet and am running into more problems, so I wanted to get the actual friction loss for size of pipe given the LPM.
RE: Oxygen friction loss calculation?
For 100' of pipe or a given length of pipe
jgreg43:
Read thoroughly and apply the fluid flow relationships given in Crane's Tech Paper #410.  There, you will find that the Darcy-Weisbach equation is valid for gases such as Oxygen - as long as you don't exceed a pressure drop larger than 10% of the intial pressure.
You can certainly set up the exercise in a Spreadsheet; I have, and so have countless other engineers that I've worked with.  Good luck.
Art Montemayor
Spring, TX
Contact a medical gas vendor and they have tables and charts used for oxygen.
Some that I use are Beacon-Medaes and Amico.
jgreg43 (Mechanical)  states
What are the problems other than following suggestion of
Montemayor (Chemical)?
