Error opening model in Catia
I have a problem opening Catia model file. Model is created od other computer nand all I get is Error message saying:
Incident report
Type: Error
Description:The Read/Write operation cannot be performed. Load aborted.
What could be the reason for that?
I'm using Catia v5R12.
Thank you gor any help.
Incident report
Type: Error
RE: Error opening model in Catia
I don't think it's a C5R12 issue, I have opened models with this version before. Do you have access/permissions to that file?
Is the file from V4 or was is saved as a .model from another CAD system ?
To work around it I had to map the unix drive from my windows machine then copy it from that mapped drive to my local drive. Probably something to do with the Network File System (NFS).
Thanx!
Brandon Jacobsen
Product Design Engineer - Catia
I know the file is not corrupt because when I use a company tool to extract the file from the Unix machine it opens fine.
nfs and samba usually use binary, but dos/windows ftp uses ascii mode which is the worst choice.
compare the file sises on both OS's. You'll find the windows one bigger!
When it happens, redownload the file after you type binary in your dos ftp session or choose binary in your ftp client menu.
