Air vents in a steam main
I am a bit confused with a design/build specification requirement for sizing air vents in a 50 psi main steam distribution line.
The project specifications call for air vents with a thermostatic element to be sized for normal operation conditions, and not for startup condition. Startup is to be supervised and air is to be released through manually controlled valves. The location of the steam air vent in question is on a 12” distribution main, with a thermodynamic trap located 5’ upstream from the indicated location of the air valve. The requested location of the air vent is in the middle of the distribution run with many lateral takeoffs down stream. It is not possible for this location be considered a stagnant area of the line.
Because the system is to have a manual startup, the thermodynamic trap should not air bind. So, during normal operation, there should be no air in the main distribution line and hence no need for a thermostatic air vent.
Question: Am I looking at this wrong? If so, what criteria should be used for sizing the air vent for normal operation (not startup)?
RE: Air vents in a steam main
http://www.spiraxsarco.com/learn
and look for modules
10.5, 11.12, and 11.13
