Smart being deleted
Smart being deleted
Smart being deleted
All,
Has anyone seen this? I am on NX2.  When I pick a curve that has been used for any free form opperation, it can be deleted.  UG updates and gives me a failure for the feature and I can pick undo so all is good.  The problem is that I can't clean up my unused curves.
Ross Parpart
Product Design Engineer
www.decoma.com
RE: Smart being deleted
Does this only happen with Freeform Features?  What specific version of NX2 are you running?  Have you called GTAC about this?
I'm running NX 2.0.4.2 MP6 & am not having this problem.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
How is the curve created? part of a sketch, basic curve, projected curve, intersect curve, etc?
I have reported this same error in PR5096123.
I not recieved a resolution to it though. In my case, I redefined a freeform surface to use new curves, deleted the old curves, and then the feature began to fail to update. I had properly and completely redifined, but still I had problems.
-Derek
DL Engineering Services
specializing in CAD Design Consultation Services
www.dl-engineering.com
Hello Rossly
The first part of your initial statement - this is a bug.
The second part, cleaning up unused curves, is it possible you have made unassociative copies of the a curve being used in a feature and they are what's being deleted? A method I use sometimes to delete unused curves - first make the first feature in the model the current feature. This will unclutter your display and make unused curves easier to select and delete.
Tinhombre,
It is a bug.
To delete unused curves I put them on one layer, delete the curves.  If the curves were used in an extrusion, they don't get deleted.  If they were used in a free form creation, they get deleted and the surface fails.  It has little to do with position on the model tree.
