Solid Edge 16 keeps closing
Solid Edge 16 keeps having a terminating error, and I can't seem to find the log file where it's telling me it's saving it. It happens randomly, sometimes happening almost immediately, sometimes it won't happen for awhile. However, a pop-up comes up saying Solid Edge is terminating. Has anybody had this happen to them before? I would like to know how to fix this so I can get back to work. Thanks!
RE: Solid Edge 16 keeps closing
I don't see your video card on the list of approved cards, GeForce cards are not recommended for cad work but I do have an old GeForce3 at home that seems to run Solid Edge ok. I have a Quadro4 750 XGL here at work that works ok but not as well as it should.
Here is a link to the SE ver16 video card test site:
http://www.solidedge.com/graphics/v16cardlist.cfm
Alternately, try backing the Hardware Acceleration slider off a single notch. This setting is found under Display Properties - Settings - Troubleshoot.
Changing drivers should be a last resort, as it can introduce more problems than it resolves.
I agree with checking the UGS Website for the latest certified/tested graphics cards/drivers.
http://www.solidedge.com/graphics/default.htm
Kevin
I installed a freeware utility to track my memory usage in order to see if it was a memory leak. Although I have never seen my memory usage go above 95%, since installing the memory tracking program, I haven't crashed since. I installed the program in January.
There are a few different freeware memory tracking utilities. The one I use is Rainmeter.
