Adding Controls to a dialog
I am trying to improve my C skills by programming an example that I obtained from the internet.  I have entered the code for a single document window and a dialog box.  The dialog box contains a EditBox and A button, I want to write code to respond to clicking the button.  I am trying to learn how these things work together without using the wizards provided by Microsoft, I think I will learn better that way.  I need to know how to implement the message map, I have messagge mapping for the document window and it function, I have placed the mapping for the buttion in the class for the document window, but it doesn't work.  I think I need to add a class for the dialog box, then put all message mapping for the dialog in that class.  My problem is I am confused on how to code the class.  Do I create a separate class? (Say Dialog.h) or what.  I would appreciate any help I can get.
