Dimensions
Dimensions
I'm using Ordinate Dimensions on my drawing, but im having problmes with the dimensions overlapping. How can I move a dimension so that it doesnt overlap with the others?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Dimensions
RE: Dimensions
CorBlimeyLimey is correct about jogging.
Consider the readabilty of your drawing. Lines that are too close together are hard to read, even if you can make out the dimensions.
Consider running ordinate dimensions down both sides of the part.
Do the new versions of SolidWorks support tabular dimensioning?
Since it is SolidWorks and you have a 3D model, there is nothing to stop you from having multiple copies of the same view. Each copy can show a different, complex set of holes. This is a drastic solution, but I have been there.
JHG
RE: Dimensions
To add a Jog, RMB the dim, Display Options> Jog.
"I think there is a world market for maybe five computers."
Thomas Watson, chairman of IBM, 1943.
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
