Dimension colors won't change
Had Dimension colors modified like I wanted.
Updated 2004 with latest SP and can't get them to change
One answer - Tools\Options\System Options\Colors\Dimensions Imported - Non imported.. <-- won't work
Is there anything else I can check before I blame the SP?
RE: Dimension colors won't change
One other thing to check using the Line color when you pick your Dimensions. Be sure the Default is "checked". If it's checked then it should be using the color for the system options above.
Scott Baugh, CSWP
DeSimulacra (Mechanical)
Thanks for help, turned out to be a video conflict.
3DVision Technologies
http://www.scottjbaugh.com
Merry Christmas
