SW 2005 DRW Borders
SW 2005 DRW Borders
Any body experience this: Line thickness on drawing templates formats look correct on screen but on printout get extremely thick?
The drwdot file is a SW2004 file that works fine under SW2004. I have the trouble in SW2005. I did save the drwdot file with SW2005 but the problem remained. The line thicknesses are the same under 2004 and 2005.
SW2005 SP0.1
SW2005 SP0.1
RE: SW 2005 DRW Borders
do a window around the whole border and make sure the correct line is picked in the line format toolbar.
2) Do you have anti0alias lines turned on under the Tools\Options\System Options\Display/Selection
3) Have you checked your line thickness when printing out in SW05?
Scott Baugh, CSWP
Cryo1 (Mechanical)
Scott,
SW2005
Cryo1 (Mechanical)
Found the problem: you have to covert the slddrt file to 2005 too. The lines are correct on print after that.
3DVision Technologies
http://www.scottjbaugh.com
Merry Christmas
The print preview appears as printed. The on-screen view appears correct.
Antialias is on. Antialias deselected did not make a difference in the print preview.
Line thickness are identical under 2004 and 2005.
