Naming or numbering conventions for drawings
We are in the process of creating a standard file name or numbering system for our Engineering department. Is there a numbering or naming standard that is simple to use and robust? Is one preferred over the other? We build yachts so we have drawings ranging from laminate schedules to carpentry details to plumbing schematics, electrical plans, paint details, spar plans, rigging plans, etc., etc.
Thanks for the help.
Peter
Peter
RE: Naming or numbering conventions for drawings
It boils down to two types of number systems, significant and non-significant. Each has Pros and Cons, and depends largely on your companies culture, strucutre and end products.
"But what... is it good for?"
Engineer at the Advanced Computing Systems Division of IBM, 1968, commenting on the microchip.
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Architectural Record had a nice synopsis on this issue last April. AIA and CSI have two standards which have merged into the National CADD Standard.
I anticipate the standard to change because the layers between discliplines aren't normalized especially with respect to AutoCAD groups being formed between different layers.
In a nutshell:
http:/
"I think there is a world market for maybe five computers."
Thomas Watson, chairman of IBM, 1943.
