Pig launcher and receiver valve selection?
Hello everybody!!
What kind of valve should be used as a mainline trap valve
at a pig launcher and receiver(6"x8")?
Is a ,full bore, ball valve better to use,than a gate valve for pig traps?
Any help would be appreciated!
RE: Pig launcher and receiver valve selection?
Yes, a full-bore ball valve is considerably better than a gate valve for the barrel isolation valve on a launcher or receiver.  These valves are operated frequently (hopefully) and the 80 or so turns required to operate an 8-inch gate valve will not make you popular with the operations guys.
Further, I always specify trunnion ball valves for the barrel-isolation valves (over floating ball valves) because they give you two seating surfaces between the line pressure and the trap - it can be a real pain if the barrel-isolation valve leaks through while you are trying to launch a pig.
David Simpson, PE
MuleShoe Engineering
www.muleshoe-eng.com
The Plural of "anecdote" is not "data"
Thanks a lot!!
Would you suggest this valve to be pneumatic, gear&pneumatic or just gear operated??
Thanks again for your time!
I've used actuated and gear-operated both and below 16-inch I find the actuators to be a pain (leaks, freezes, difficulty dealing with low pressures if you pull the system pressure down, etc.).
The sequence I require for launching valves is (starting with the trap isolated and blown down, see my web page under "Samples" "Rules of Thumb for Gathering Equipment" for a description of what I think should go into a launcher design):
1.  Load pig
2.  Open kicker
3.  Open barrel-isolation valve
4.  Shut side valve
5.  Re-open side valve after pig has left
6.  Shut barrel-isolation valve
7.  Shut kicker and blow barrel down.
With that sequence you never have any dP across the big valves so I think an actuator is a waste of money and an addition of unnecessary complexity.
David Simpson, PE
