Signal pole design
Signal pole design
I'm a new designer to the industry with a general understandin g of statics and Strength of materials (trig based) I am looking for a mentor some one to walk me through a simple design say camera pole 40' high 8 sided with a 1.5" thk X 19.5" sq. base plate 1/4" astm a572 pole astm a36 base welded wtih an upper fillet of 5/16" and lower of 1/4" I've done beam deflection for standard I beam type structure but i'm having a harder time with a hollow tapering prismoid (.14 taper.) Is there someone out there willing to help me out here?
RE: Signal pole design
I sounds to me that you are looking for someone to show you how to solve and or design a pole structure. There are many factors involved in the design. It is not simple for the first timer.
I will be nice and give you this link for a step by step design example for single tapering pole. Read it and try to understand it and read the referenced codes. Buy hem if you do not have them. Also invest in some books and attend seminars. There are many of them and they are administered all over the country.
Here is the link: http://www.c-conceptsinc.com/files/example2.pdf
Let me caution you that the design of the pole is the easy task. The hard task is to design the base plate connection and the foundation.
Good luck
Lutfi
www.cdeco.com
It has loads, design criteria, etc. as well as deflection formulae for tapered poles for a variety of load cases.
"Engineering Sign Structures" by Benjamin Jones. His examples are well-presented.
I don't do much sign structure/light pole design but I agree with Lufti, the hardest part is the base plate connection and foundation.
