finding the path in VBA
Is there any function in VBA autocad that will return the full path of either the My Documents or Desktop folders?
object.GetSpecialFolder only returns windows,temp or system folders.
RE: finding the path in VBA
Borgunit, This doesn't seem to work. I cant quite get it to work with VBA from autocad. I already have the SHfolder.dll file on my machine but I can't seem to access SHGetSpecialFolder. Soat this point I can't seem to use this. Also this doesn't seem to work in VBA for autocad. Do you have a code slice or some documentation?
