Pump Problem
Pump Problem
Pump Problem
We have a Vacuum Pump that we are trying to gear down to reduce the load on our generator.  We've tried using a one of our old VFD's, but all our level switches in our system change state as soon as the drive turns on.  Space is limited between the motor and pump as well.  Motor face to pump face is probably 15" max.  The pump and motor are direct coupled.  I've started looking into some options for pulleys or gear couplers of some sort.  Does anybody have any other ideas?
Jenkins
RE: Pump Problem
What kind of a pump?  Might be able to reduce the power requirement by throttling, or disabling some stages.
RE: Pump Problem
Is the problem in bringing it up on line, or maintaining it?
RE: Pump Problem
this is the high end, have you looked in to one of the shaft mounted torque converter that Browning makes, the take the shock load out very well
Bill Loutzenheiser VP-CTO
Phoenix Castings
Central Nebr., USA
RE: Pump Problem
What was the system problem with the vfd and why do you think belts/pulley's won't create same problem?
In general vfd's are more flexible than pulleys and gears since you can change the speed on the fly.
RE: Pump Problem
Check out the MagnaDrive, see their website by that name.
