Concrete for grout
Concrete for grout
Would you substitute concrete for grout?
The concrete would be a plant mixed f'c=3500 psi mix.
Largest aggregate size would be 1/2" diameter.
I think I need to check code requirements.
RE: Concrete for grout
The contractor wants to use the footing concrete mix with extra water added at the site after pouring the footings.
I am going to deny the request.
1. the concrete mix has an air entraining admixture
2. no way to control the mix w/c ratio at the site.
These are about 2 or 3" in diameter and about 4 inches long
(I don't know the size exactly)
If not, what are these intended for?
This was kind of a on the fly question.
Mortar, grout, and "concrete" are all concretes with different aggregate and slump ranges.
My decision to deny the request has to do with execution in the field. The contractor proposed to use leftover concrete in a truck for grout. The concrete was a 3000 psi mix with 1/2" aggregate and air entrainment admixture among other admixtures. The contractor proposed to add water to whatever unknown amount of concrete and then use as grout.
