RowSource problem with Combobox in Excel
Hello all,
I have 20 comboboxes on a userform in excel. Each box are supposed to drop down to reveal a long lists of values (thousands, say).
When the userform initializes, the comboboxes are empty. Then a script is run to set the rowsource for each combobox and it works fine. However, after the userform is unloaded, the rowsource definitions are lost - ie, next time I show the userform, I would need to run the scrip to set the rowsource again. I could set the rowsource manually by typing in the address in the property box; but it wouldn't be dynamic.
Is there any way to set the rowsources programmatically and make them permanent?
Thanks.
Justin
Thanks.
Justin
RE: RowSource problem with Combobox in Excel
Good Luck
johnwm
________________________________________________________
To get the best from these forums read FAQ731-376 before posting
UK steam enthusiasts: www.essexsteam.co.uk
Thanks.
Justin
Good Luck
johnwm
Thanks very much for your help. I'm a bit lost - Autoload and ListFillRange are properties of a listbox right? wondering how I can make a combobox workk the same way?
Thanks again
Justin
Good Luck
johnwm
