2D view position relative to solid position in V4?
Current condition:  I have an assembly that was created in space window.  The 2D geometry was then created using auxview2 for each part in the assembly.  Our drawing standards dictate we have multiple parts on each sheet (draft). Then somewhere down the road a revision takes place and one of the existing parts (solids) has to be located differently and also the geometry changed slightly.  When I go to update the detailed part it also moves to a different location on the drawing sheet.
Is there a way to maintain the position of the auxview2 if the associcated model changes position?
RE: 2D view position relative to solid position in V4?
Sorry...
Don't think there is any solution
INDOCTI DISCANT ET AMENT MEMINISSE PERITI
Eric N.
catiav5@softhome.net
