Corrosion of Aluminium Parapet posts
does anyone have experience in the corrosion of aluminium parapet posts
i have the situation where a post exploded upom drilling a hole into it
i believe that salt via salt laden water from the road was sucked into the interior of the post through a pressed joint in a temperature cycle leading to areaction with the aluminium producing hydrogen gas
a milky fluid is found in the base of the post presumably as a residue of the reaction
i am not a chemist and i need to understand this in simple language
i am about to test all components to prove this and would appreciate any help
RE: Corrosion of Aluminium Parapet posts
The milky fluid likely contains aluminium hydroxide, a typical corrosion product when water is plentiful.
Cory
