addin load every time
I found a custom addin menu someone has created. It works pretty well. It gives you an ini file that you can modify to your needs. To get it to work you have to open the .dll in SW and then it is available in the Tools addin section. My hangup is how do I get it loaded everytime I launch SW? I thought it might be because I was using a specific template, but I addedin the .dll and saved as a template. Still didn't work. I'm sure I'm missing something pretty simple just can't put my finger on it.
I'm using SW04 sp4.1
Thanks in advance.
Thanks in advance.
RE: addin load every time
Next time, look for the addin under "Tools --> Addins" before trying to reload it. It could be the addin is loaded but not turned on.
Next time you open Solidworks go to Tools-Add-Ins and check to see if your Add-In is selected. If it is, you can right-click anywhere on the standard toolbar and see if your custom toolbar appears in the list (you can select it if it does and it should appear).
When you create a custom toolbar you are required to specify which document types you want the toolbar to appear for. It could be that your toolbar is set up only to appear for parts or something.
Also make sure the DLL is at the same location on your hard drive as it was last time you opened solidworks (Solidworks had to be able to find the DLL to load it).
An add-in DLL is a DLL like any other. Windows requires registry pointers to the DLL in order for it to run in the Windows environment. SolidWorks also requires some registry pointers to the addin DLL.
When you drag-drop an addin DLL to SolidWorks, SolidWorks takes care of registering the addin with Windows and with SolidWorks. This should be a one-time-only deal.
Sounds like the registry is somehow lose track of the addin components. This is more likely to happen when addins are on a network.
http://www.EsoxRepublic.com
It still has some bugs like wrong spelling and menus supposed to gray out in drawing environment do not but otherwise it's pretty cool and creates an easy way to keep your macros together and readily available.
In my case reloaded everytime without any problem. I do have administrator rights on my local machine.
Thank Mike for it I think he is lurking out here. He is also one of my customers... good man he is!
I hope that works out for you.
Scott Baugh, CSWP
3DVision Technologies
http://www.scottjbaugh.com
Merry Christmas
FAQ731-376
FAQ559-716 - SW Fora Users
