Sketch on a section
Sketch on a section
Sketch on a section
Problem: section a part and create a sketch on the section (actually the plane through the section). It appears that you can't select the edges of the section and convert them to sketch lines. Is there a work-around?
RE: Sketch on a section
Tools --> Sketch Tools --> Intersection curves
In a 2D sketch, this will get the section curves of surfaces intersecting the sketch plane.
Turn off section, change from color solid to wireframe (can't remember the correct terms right now), then select the edges.
