Intersects with coordinates
I'm attempting to find the insersection of two lines and store that points X and Y in an array before putting it in a spreadsheet.  I can't figure out how to get the X and Y coordinates from the Intersection point. Below is the code I'm using.
Dim FirstLine As AcadLine
Dim SecondLine As AcadLine
Dim ThirdLine As AcadLine
Dim IntersectionPt As Variant
Set FirstLine = ThisDrawing.ModelSpace.AddLine(Pt1, Pt2)
Set SecondLine = ThisDrawing.ModelSpace.AddLine(Pt3, Pt4)
IntersectionPt = FirstLine.IntersectWith(SecondLine, acExtendBoth)
What I've tried is:
X1 = IntersectionPt(0): Y1 = IntersectionPt(1)
but it doesn't work. Any suggestions?
RE: Intersects with coordinates
Just a check, are you checking that they return an intersection or not before you assign its values?
"Everybody is ignorant, only on different subjects." — Will Rogers
I know they intersect. I'm looking at the lines I'm working with and can't get the code to work.  Does this work with lines or just objects? It seems like I'm having trouble converting the variant data into numeric data. Could that be the problem?
Maybe, do you get an error and what does it say if you do?
On the last line it says Type Mismatch.
The IntersectPt is a variant and is suppose to have an X, Y and Z (I think it's suppose to have a Z) coordinates. By the way, that X1 that I'm trying to get to receive the coordinates from IntersectionPt is a Double.
Any more ideas?
