Plane through circle
How do you create a parallel plane through a circle? This is for SW2005. Default wants a point. The temporary axis can be selected but is not valid, and you can't select its end point. You can select the circle or shaft edge but the choice of selecting its center is not offered. I have had to create a sketch and put a point at the center of the circle.
RE: Plane through circle
