Link equations to custom properties?
I should be able to find this myself, but can't...
First, I know you can link a dimension value to a custom property--what's the format (what do you put in the custom property field)?
Next, can you do the same thing with an equation (variable)?  Say I have an equation A = B * C; can I get "A" into a custom property?  I tried putting =A and ="A" in there with no success.
Help? Thanks,
Brian
RE: Link equations to custom properties?
No need to know the format ... just highlight the custom properties Value field & then click on the dimension.
Not directly from the equation, but the dimension that "A" represents can be inserted into the Custom Properties as per my previous post.
Sweet!  I did as you said, and voila!  There was the value I wanted.
But wait, there's more!  You actually CAN link an equation's result to a custom property, using this format:
"name@PARTNAME.SLDPRT"
where "name" is the name of the equation ("A" in my example) and PARTNAME.SLDPRT is the name of the file containing the equation.  Using this method, I don't have to go through the dimension to get the equation value.  Try it!
Thanks for the help,
Brian
