rich LNG fired in gas turbine- NO2 increase
We have several large combustion gas turbines located in Florida, USA. The gas pipeline company indicates that the source of gas will shift to imported rich LNG in 2007-2008. The new fuel gas will have 1.2% butane and 2.75% propane.
According to technical papers based on lab tests of model combustors, the increase in butane and propane will increase the exhaust levels of CO and unburned hydrocarbons, and these unburned hydrocarbons will form radicals HO2 and O which will oxidize NO to NO2. However, I am not able to find any reports of actual field test data from operating gas turbines that burn rich LNG.
Can anyone advise if they have access to test data of gas turbines that burn rich LNG ( Japan, Korea, Spain), if so, what is the expected increase in exhaust NO2 levels?
If the NO2 level exceeds 13 ppm in a simple cycle turibne, the exhaust will exhibit a visible "yellow plume". If the ratio of NO2/NO exceeds 1:1, then the SCR performance will suffer.
RE: rich LNG fired in gas turbine- NO2 increase
I'd be rather surprised if the turbine vendor (I presume either GE or P&W) couldn't provide the operating field data you're looking for.
Orenda
GE alluded to the possibility that the NO2 would increase at part loads, but no other iformantion is available at this time.
I may have a solution for your NOx problem.
See a picture of the WhirlArc at www.oxilume.com
Todd
www.oxilume.com
